04-08-2017 09:12
04-08-2017 09:12
Could someone please point me to the help section that deals with changes to the canned signature block? I upgraded from a CHR to a Charge 2 (and what a beautiful piece of machinery it is !), thus necessitating a change to my signature block which doesn't recognize that change without correction on my part.
Gary
Best Answer04-08-2017 11:09
04-08-2017 11:09
There is no canned signature block unless you're a Moderator or a Community Council Member.
I've seen people who add a signature at the bottom of their posts, which I think would be a copy and paste.
Glad you're loving the Charge2!
04-08-2017 11:09
04-08-2017 11:09
04-08-2017 11:51 - edited 04-09-2017 07:11
@Odyssey13 OK, tnx. I'm a former CC member so I'll go to them to sort it out.
And yes, the Charge 2 is a significant improvement over the CHR!
[Edit -- don't know what happened to the address on this e-mail. Clearly it belongs to you.]
04-09-2017 07:08
04-09-2017 07:08
@Odyssey13 OK. Well you may bump into Callie or Allison: I wrote them a note requesting the correction too. Looks like I will get lots of attention 🙂
Thanks for your support. Fitbit at its best.
Cheers,
Gary
04-09-2017 09:16
04-09-2017 09:16
@garybartlett I hope you're doing well! Not sure if I understood correctly but you shouldn't have any restrictions (just the ones outlined in the Community Guidelines) about changing your signature. Feel free to follow these steps to add your new Charge 2 to your signature the way you want.
If this wasn't what you were actually asking then please let me know!
04-10-2017 05:47 - edited 04-10-2017 05:51
@AlvaroFitbit I would be just as happy (happier) if you removed my signature block entirely. Someone has changed it and made it worse.
For all the postings I do, I can just manually type in my details.
Gary
[Edit. See what it now reads below? Makes no sense]
Gary B | Canada
CHARGE 2 daily
04-10-2017 07:44
04-10-2017 07:44
@garybartlett It is really odd that you can't change your signature. Did you check the steps on the link in my previous post? I will gladly help in any case but I sent you a PM asking for more information.
Looking forward to your reply.
04-10-2017 08:22 - edited 04-10-2017 08:34
Hi Alvaro:
The easiest solution to my problem is simply to remove my signature block altogether rather than waste any more time and effort on something that I only use maybe once per month. Or the way you have it now: ``Gary B Canada Charge 2`` is perfectly adequate.
For whatever reason I cannot find the gear icon you mention in your instructions and therefore cannot change my signature block myself.
I am running Win 10 and the dashboard on a laptop. I am also very sick and I`m trying to get this signature block issue behind me.
Plse confirm receipt of this e-mail.
Cheers,
Gary
04-10-2017 08:59
04-10-2017 08:59
@garybartlett If you want to change it just go to your browser (I suggest you try Chrome or Firefox) go to the community and click on your picture on the top right corner, there you will see the settings option, on the new page you can click on Personal and on the submenu click Personal Information to edit your signature.
Regarding the options you said that the current signature is ok so should I leave it or just delete it? Just select one option and it shall be done. ![]()
In no time this will be fixed for you.
I look forward to your reply.
04-10-2017 09:14 - edited 04-10-2017 09:17
@AlvaroFitbit Leave it the way you have it now: "Gary B Canada Charge 2" and I think everyone will be happy 🙂
Thanks, Alvaro.
[Edit: And I found the gear icon under my picture!]
04-10-2017 09:34
04-10-2017 09:34
@garybartlett Glad I could help and happy you found the gear icon so you can make any changes you want whenever you want.
Hope to see you around more often!
04-10-2017 11:06
04-10-2017 11:06
@garybartlett Also note that the forum layout has changed slightly - you can now click your profile image at the top-right to bring out a menu that includes the "Settings" option.
Alternately, you can click here to go straight to your Signature settings.
04-10-2017 11:34
04-10-2017 11:34
Best Answer04-10-2017 16:29
04-10-2017 16:29
@garybartlett please feel better soon. It's miserable to be sick when spring is just getting started!
Best Answer06-21-2017 07:39
06-21-2017 07:39
The Signature field is missing on my Personal page. I've been trying to add a signature myself.
FitBit Aria
MyFitnessPal and MapMyRide, Garmin VivoSmart
