05-21-2024
14:33
09:20
AndreaFitbit
05-21-2024
14:33
09:20
AndreaFitbit
I have recently bought a Sense device refurbished but I am not able to see the option to enable snore detection which was part of the reason i bought this device. I have purchased premium and my device is synced/up to date. is this an issue others are facing ? has this feature been deactivated?
Moderator Edit: Formatting.
Best Answer05-21-2024 15:04
05-21-2024 15:04
05-21-2024 15:35
05-21-2024 15:35
Unfortunately that option is not available to me at the moment, picture attached
Best Answer05-21-2024 16:07
05-21-2024 16:07
@mnnamah I’m going to flag your post to get a moderator to help you. I found an old thread that says it might have been removed because of battery drain issues. I want to add that Fitbit’s Help article gives a different path, but it goes to your screenshot.
Laurie | Maryland
Best Answer05-21-2024 16:19
05-21-2024 16:19
As mentioned, it is a big battery drain even if you find it, and I think you can find a similar app on you phone where the battery drainage is probably not as big a factor.
Best Answer05-21-2024 23:02
05-21-2024 23:02
Thank you for the assistance but I had a versa 4 and 3 in the last month and returned both because this feature did not appear to work. I do not mind the battery drain as I only wear my fitbit to sleep (it is on charge in the day). If there is no explanation for this issue I will have to return the device unfortunately. I have apps on my phone for snore detection but I do not like them and refuse to pay multiple £80+ subscriptions to track my sleep
Best Answer05-21-2024 23:14
05-21-2024 23:14
I found something on google that appears to have worked
Best Answer05-22-2024 09:40
05-22-2024 09:40
Welcome to the Fitbit Community, @mnnamah. I'll be glad to assist with your snore detect inquiry.
With a Premium subscription, turn on the snore and noise detection feature to allow the microphone on your Fitbit Sense to track noise, including snoring from you or someone next to you. By analyzing noise information every few seconds, your device can track the overall noise level of your surroundings and check for snoring throughout the night. When you wake up, your nightly results are summarized in a report.
To turn on or turn off snore and noise detection:
To see your snore and noise report:
Note that if your device runs out of battery during the night, the noise level chart will be missing some data.
To delete snore and noise data:
Thanks for the heads up and your assistance @LZeeW, @JohnnyRow.
