I only get a complete sleep log once or twice a week. Many times there is a gap of 2 - 3 hrs at about 2:30 so it can't create a log. Anyone know what might be causing this? Thanks.
17:24
05:02
04-29-2020
17:24
05:02
@MrsT2020 Welcome to the Community. Thanks for getting in touch about this.
I would like you to try the following:
- Restart your Fitbit
- If your device doesn't have heart rate, change the sleep Sensitivity to Normal
- Try sleeping with your Fitbit on your non-dominant hand
I would like to move your post to the correct board, please let me know the Fitbit model that you have.
Let me know the outcome.
Best AnswerI was able to restart my Charge 3. I do wear it on non-dominant arm. Last night I did get about 5 hrs that does show a lot. Then there was a gap and my last hour of sleep has minimal data. It does show for most of the night that my heart rate stayed above my daytime resting rate. Also I was quite restless. I do have sleep apnea and take a prescription for restless legs. I just don't know what interrupts the Fit bit data. I am not awake or up out of bed although it sometimes corresponds to a visit to the bathroom.
