04-19-2020 20:30
04-19-2020 20:30
Hi, I've been having an issue with my current guided program.
I have FitBit Premium and started the program Push Up Prep through the FitBit app. I open the fitbit app to get my workout, but when I've finished it (through FitBit Coach), it does not count it towards the Guided Program. It displays 0/3 even though I selected the workout from the guided list and launched it.
I've tried re-doing the workout, and nothing changes.
I have an Inspire HR, and I only use the fitbit app to then launch the workout in FitBit coach.
I've seen posts like this dating back at least a year, and it seems like nothing has been resolved.
Best Answer04-19-2021 01:59
04-19-2021 01:59
Hi there, I started a "push up prep" workout on the Coach but my Fitbit App still says "0/3 workouts for the week" so has not pulled in the workout from FitBit Coach.
I have tried disconnecting the Coach app and reconnecting, but it still does not show in the FitBit app.
04-19-2021 20:33
04-19-2021 20:33
@SilviaFitbit i am new user of a new Versa 2. Same problem here. I came here to look for a resolution, and am dismayed to see this is a problem unresolved for nearly a year. What is the ETA on resolving?
04-20-2021 02:30
04-20-2021 02:30
I have exact same problem as you.
04-20-2021 16:09
04-20-2021 16:09
Hi everyone,
Thank you for the troubleshooting performed and the details mentioned. I see where your disappointment is coming from.
Your feedback is really appreciated, be sure that our team is aware of this and working towards a resolution, your patience and understanding is appreciated while this is resolved.
See you around.
Best Answer04-20-2021 17:11
04-20-2021 17:11
I am having this problem for a couple of days now and have tried to uninstall/reinstall both apps.
04-21-2021 13:16 - last edited on 04-26-2021 20:19 by LiliyaFitbit
Did you start a workout sessions on your Fitbit device also? If the device doesn’t record an actual work out session, either by manual start or auto record, it won’t be logged. Default for auto record is min 15 minutes duration.
Med vennlig hilsen
Best Answer04-21-2021 15:33
04-21-2021 15:33
Same issue, also tried resyncing and have most updated versions of Coach and Fitbit App
Best Answer04-21-2021 17:40
04-21-2021 17:40
Is it only the workouts that aren’t tracking? Mindfulness works
Best Answer04-21-2021 19:52
04-21-2021 19:52
Umm this is not fixed there is another thread talking about syncing not working for weeks. How was this fixed? I would appreciate on what we should be doing to make the syncing work. Thank you
Best Answer04-21-2021 19:53
04-21-2021 19:53
I can’t get any programs to register in the push up prep.
04-22-2021 07:21
04-22-2021 07:21
This is still a problem and is not fixed. I still cannot log. Fact it hasn’t been syncing in the last two weeks. there is another thread that shows this hasn’t been resolved yet.
I have unlinked re-linked deleted added reset etc fitbit apps. I made sure all the updates were completed (mine didn’t need any updating )and still the syncing is not working
04-24-2021 18:58
04-24-2021 18:58
Hello@sylviafitbit,
while I appreciate that guided session have days chosen and it is recommended that workouts are done in those days, it seems the design and technology should also recognize them on off days... life does not always go according to plan.
While I enjoy the guided sessions, I find navigation in the Beginning Running program very confusing...... forcing certain days... if you select a M-W-F schedule, you can’t choose to run (as part of the program) on a Saturday or Sunday... it does not seem to track the runs in a timely manner... and is confusing when it does track it.... lots of promise in the programs, but still not quite there. Thank you
04-26-2021 03:41
04-26-2021 03:41
Hi everyone!
This has been solved for me on Saturday.
Suddenly, after finishing my workout, the application decided to store the session as usual and it also took into account the missing sessions from the time it was not working properly.
Still, the sessions weren't sent to Fitbit, but that's not a big issue for me. What's important is that now the sessions are calibrated on my actual workout frequency, whereas I noticed they were shorter while the app was skipping to record the sessions.
Cheers
04-26-2021 03:57
04-26-2021 03:57
Hi Antonio,
have you done something to solve the issue? Thanks for your support.
Mirko
Best Answer04-26-2021 07:03
04-26-2021 07:03
Hi Mirko91,
The only thing I did, now that you make me think about it, was complaining in the feedback of my previous workout.
Until I didn't finish the next one nothing happened though.
Best Answer05-05-2021 13:39 - edited 05-05-2021 14:17
Edit: After rebooting phone AND fitbit and then syncing several more times, ten minutes later it did allow me to turn the tile. Fitbit is SO slow at syncing. Ugh!
Don't know what the fix was supposed to be but I have one last tile to turn, 7.7 miles, and have more than enough do so, but all it does is wiggle so your fix didn't work. AND there is no answere here in your message!
05-07-2021 00:35
05-07-2021 00:35
The problem is not fixed for me…in fact, it started around the time of this fix! The last few weeks, at least 3 weeks, my Fitbit has consistently not logged Running Program completions from Fitbit coach that on completed on Thursdays. Sometimes, it wouldn’t log another day as well, so I’d end up having to repeat the week. This past week it caused it to start me all the way back over so today (still Thursday Hawaii time) is my last day of the week. I have previously completed the program, so it has saved “previous feedback” for off days in Fitbit. Fitbit coach always has a record of me completing that day’s workout. Some weeks, I run every day so it was surprising to notice when my days weren’t counted. I use the program as more of a reminder and a benchmark than anything. This week, the previous days counted in Fitbit, so it’s going to let me move on to week two even though Thursday will not count.
05-13-2021 06:48
05-13-2021 06:48
Hello.
I am doing the beginner running program and completing the workouts on the workout days. I have a Versa 2. This issue is very frustrating.
05-13-2021 08:36
05-13-2021 08:36
Best Answer05-15-2021 00:27
05-15-2021 00:27
This remains a problem. I have a premium subscription and a Fitbit sense. Beginner fitness workout. Please help!
