03-02-2021 03:52
03-02-2021 03:52
All of my mindfulness sessions that I saved as Favorites are no longer there. There is no option to choose “select all”
Did the format change and if so why?
Best Answer03-02-2021 13:51
03-02-2021 13:51
I tried to do a session last night, & it shows only 6 options (4 premium) in the app. I can't access all the other options, including the ones I typically use. I logged out & also uninstalled & reinstalled app, but it's unchanged. Very disappointing.
03-02-2021 14:18
03-02-2021 14:18
Hi! I went into my app this afternoon to look around a bit. I found my saved “favorites “! 😀. Go into your Discovery section on the bottom of the Fitbit screen. Scroll down and chose the Mindfulness—see if you can find your previous selections . That’s where I found mine!! Hope this helps!
03-02-2021 16:58
03-02-2021 16:58
Also, if you click on the Premiun arrow at the bottom, you click on Mindfulness and they are found there too!😀
03-03-2021 19:39
03-03-2021 19:39
Ty for the tip re: in discovery section
