10-05-2023 08:19
10-05-2023 08:19
My premium app for my charge 6 just changed automatically today. Don't like configuration. Can I change it. Doesnt show battery level like the old version or I can't find it, and would like to know If I can change the way it looks as far as the metrics they show. I would like to see my heart rate on top without having to scroll down. Give me the old configuration. This one sucks.
Best Answer10-08-2023 14:49
10-08-2023 14:49
Hi, @Frenchsar , there are many customisations available on the new app. You can certainly have your heart rate at the top depending on your focus. The focus options in the new app are “Get more active”, “Sleep better”, “Manage weight”, “Manage stress” “Improve heart health” and then the option to set a custom focus.
To change your focus, from the opening screen of the app click on the small pencil icon top right. Then click on the box under “set your focus” and swipe left to see the options available to you. Each category will have a top statistic and then 3 more sub statistics. If none of the options suit you, then go to the final custom focus screen and choose your four stats.
Once your focus is set you can also move groups of others stats up or down.
As for battery, you will get the most accurate indication on the Fitbit itself (swipe up from the clock screen). The app will tell you the general battery stat (full, medium, low) if you click on the icon top left on the opening screen (its a smart phone and watch) and then click on your Fitbit.
I hope this helps. Welcome to the forums!
