02-22-2023 14:19
02-22-2023 14:19
I wear my Fitbit 24/7 except for the day I charge it. Since starting the premium trial, the Readiness Score does NOT show anything. NO sleep score, yes my fitbit says the sleep function is set to on and on my wrist. The Health metrics are not working either except for the resting heart rate. Before starting the free premium trial, they actually worked. HELP!!!!
02-28-2023 17:10
02-28-2023 17:10
Welcome to the Community, @Jin-X.
Thanks for bringing this to our attention. I understand this started after your Premium trial, but may I know if you've changed anything on your routine? Keep in mind most of the features mentioned required 3 hours of quality sleep. If you move a lot during your sleep, the sleep session is too short or if you slept in a position that prevented your device from getting a consistent heart-rate reading, you might not get this data.
In the meantime, please give a try to the following:
02-28-2023 17:10
02-28-2023 17:10
03-01-2023 04:39 - edited 03-01-2023 04:39
@Jin-X Any update with @LizzyFitbit recommendations? What device are you you using and how long have you been using it?
03-01-2023 10:24
03-01-2023 10:24
Thank you so very much for your help!!! Finally, able to get data this morning! I struggle with getting more than 3 hours of quality sleep, but I did do the update and resboot!!! YAY! Thanks again!!!
03-01-2023 10:28
03-01-2023 10:28
@eezeepee Yes finally got some data! YAY! I did follow @LizzyFitbit's advice and so far so good. I've struggled to get more than 3 hours of sleep a night but finally this month, I've been able to get in 4-5 hours a night so that helps the data for sure. Thanks for checking.
03-03-2023 10:50
03-03-2023 10:50
@Jin-X It's great to see you around. @eezeepee Thanks for stopping by to help our friend.
@Jin-X You're very welcome! I'm happy you're getting this data and thanks for trying the suggestions shared above. By the way, I'm going to mark my post as the Best Answer to help other members experiencing similar issues.
In case you have some spare time, let me invite you to visit our Health & Wellness board where you will find great tips and encouragement from other members. Have an awesome weekend ahead!
