05-05-2021
21:40
11:02
SilviaFitbit
05-05-2021
21:40
11:02
SilviaFitbit
I have a problem downloading my wellness report. Once it’s generated I click the notification received on my inbox and click download but the screen just keeps loading.
11:05
16:04
05-06-2021
11:05
16:04
@svaldivia Welcome to the Fitbit Community. Thanks for the details mentioned.
Try the following troubleshooting:
- Log out from the Fitbit app
- Force quit it
- Restart your phone
- Log back in
Hope this helps.
05-06-2021
11:05
16:04
05-06-2021
11:05
16:04
- Force quit it
- Log back in
Hope this helps.
08-29-2021 18:06
08-29-2021 18:06
I tried this several times. Inbox indicates report is "ready" but it never downloads so I can't see it. What now? I have yet to see the benefits of this subscription.
08-31-2021
15:21
16:03
08-31-2021
15:21
16:03
@The-Captain Welcome to the Fitbit Community. Thanks for the details mentioned.
I see where your disappointment is coming from.
If you have an Android phone and you don't see the report in your inbox, check the Files app on your phone. Open the Files app > search for your Fitbit Wellness report > tap to open the file with Adobe Acrobat.
Check out this article to learn all about Premium features displaying on your Fitbit app.
Hope this helps.
Best Answer01-10-2022 10:51
01-10-2022 10:51
Ditto. Same problem. Same repeated disappointment. Cancelling subscription as a result.\
02-18-2022
16:48
06:40
EstuardoFitbit
02-18-2022
16:48
06:40
EstuardoFitbit
This did not work for me. Any other suggestions? Why can't I get the wellness report through the web site?
I have the same problem. never finishes downloading or preparing for sharing. No value in Premium features.
This does not work! Plus why should you have to go through all that. Seems like this was been an issue for a while. It's a bug that should be fixed by Fitbit.
Moderator Edit: Merged replies
02-18-2022 17:05
02-18-2022 17:05
02-18-2022 17:07
02-18-2022 17:07
07-24-2023 18:26
07-24-2023 18:26
This didn't work for me, but I got help via chat. I had to uninstall the fitbit app and reinstall it, agreeing to all the permissions. Then it worked.
Hope that helps others!
