09-21-2017 06:28 - last edited on 09-24-2017 05:07 by LanuzaFitbit
Hello, fellow Fitbitters. I have a question that I'm hoping someone can help me resolve.
I use the Fitbit Audio Run & Walk beta often because I enjoy the coaching I receive while walking. The reminders to tighten my core, let my arms swing freely, pick up the pace, and breathe have helped me tremendously. However, I can't seem to figure out how to map my routes so I can share them with my friends. Is this integration not available within the Fitstar app? It's hard to believe that I can't use GPS tracking and Fitstar at the same time! Should I perhaps use the "Walk" mode on my Charge 2 alongside the Fitstar app? Wouldn't that essentially double-log my activity?
Thanks!
Erin
Moderator edit: Format
09-28-2017 09:16
09-28-2017 09:16
Hey @ErinJ80.
In this case I'd say that the best way to go about it would be to select the 'Walk' or 'Run' activity on the Charge 2. It will then try to connect to your mobile device in order to access the GPS information and map the run that way.
Hope you find this useful! Let me know if you have any further questions.
