12-10-2018 02:25
12-10-2018 02:25
Please advise why the distance graph/chart does not show the historical values. The figures show but the bars on the chart are all zero.
I am using a Samsung Galaxy S8+ and all software and apps are up to date.
Thank you.
12-10-2018 19:15
12-10-2018 19:15
I’ve also had this issue and, in my experience, the data should reappear if you either exit out of the particular section you’re trying to view or restart the app, with the latter being more reliable.
Hope this helps, as far as I can tell, it’s a simple glitch in the Fitbit app that is annoying but doesn’t present an actual risk to your fitness data.
12-10-2018 19:15
12-10-2018 19:15
12-10-2018 19:52
12-10-2018 19:52
Thanks very much. I since found my problem...... I had the daily distance target set to 10,000km and not 10km.
