09-09-2017 07:27
09-09-2017 07:27
Hi Y'all I'm new to this. When I look at the log under 'weight' there is a tab for lean vs weight. There isn't any data displayed there. I don't know how to enter it or get it to track it. Any help is appreciated.
09-09-2017 09:01
09-09-2017 09:01
Hi, @RebekahE! When you enter your weight, you can enter both weight and body fat percentage. If you have a scale like the Aria, it will estimate it for you. You can do some reading on the web about other methods you can use, like caliper measurements, too. If you enter this value, Fitbit will use it to calculate other information like your amount of lean and fat weight.
MakMak | Community Council
09-23-2017 07:46
09-23-2017 07:46
Thanks! That helps!
