04-26-2017 08:54
04-26-2017 08:54
I had a problem with my app . So reinstalled it. But I have lost some tiles! Please help.
04-26-2017 11:09
04-26-2017 11:09
It depends a bit on which app you mean, but on mobile you can swipe to the bottom to find the 'edit' button and find either an x to remove tiles or a + to add them.
In the Win10 app you can click on the pen/edit in the top right menu to get the option to add or remove tiles.
Hope this helps
04-27-2017 09:49
04-27-2017 09:49
@ThatGreen nice suggestion! Keep it up.
Welcome aboard @Kat.358! By what you are describing it sounds like your tracker might have gone unpaired during the process of deleting the app. Please check if your tracker has been unpaired. If it has been unpaired, please follow these steps to pair your tracker once more. Hope this helps. Let me know if your tiles appear again.
Looking forward to your new comments!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
