10-24-2020 13:59
10-24-2020 13:59
Recently had issues with the back button, keep short cutting to my stop watch, did a factory reset and fixed the issue but no longer we the option to log water on my fit bit ionic or see my sleep results, it doesn't exist in the settings at the bottom either it's just gone any help would be greatly appreciated
10-24-2020 16:43
10-24-2020 16:43
I just verified that they exist and I was able to add Water to my Versa 2 - - - This is the Web Dashboard board, you may want to visit the Ionic board .
Good luck and welcome to the boards.
10-28-2020 23:54
10-28-2020 23:54
Thanks mate sorted it 👍
