01-14-2020 08:34
01-14-2020 08:34
I just purchased a brand new Fitbit Versa 2 and have had it less than a week. My weight keeps changing like others wrote. But a huge change. I weigh in the 140's and it keeps changing to 328 lbs. (or close to that) every few days. Any idea how to fix this?
10-18-2019 04:07
10-18-2019 04:07
I enter my weight and then a day later it has changed itself. Usually close to what i put in but always different. Anyone else having this issue and any idea how to fix it?
10-19-2019 16:33
10-19-2019 16:33
@jessmills1982 It's great to see you around. Thanks for the details mentioned.
It's pretty weird that your weight is changing. In this case, I would like you to log out from your account and clear cookies and cache, after this please log back in and edit your weight.
Also, please make sure that you're not logged into any other device that someone else might be using.
Keep me posted!
01-14-2020 08:32
01-14-2020 08:32
I just purchased a brand new Fitbit Versa 2 and have had it less than a week. My weight keeps changing too. But a huge change. I weight 149 and it keeps changing to 328-ish every few days. Any idea how to fix this?
01-15-2020 13:24
01-15-2020 13:24
@Savy_V It's nice to see you around. Thanks for letting me know that you have a Versa 2.
I would like you to make sure you have changed your units of measurements to pounds and that it's not in lbs. Check the instructions here: How do I change the units of measurement on my Fitbit device?
If you're still experiencing the same, please provide me with a screenshot of what you're seeing.
Keep me posted. I'll be around if you have any additional questions.
01-16-2020 04:24
01-16-2020 04:24
It happens to me too. I just bought mine 6 days ago. It’s converting to kg by multiplying your weight in pounds by 2.2 but not changing the unit! So it looks like you (and I) are 300+ pounds when we are really 130-140ish! I can’t figure out how to fix it because all the units are set to lbs!!
Could someone help us???
01-18-2020 11:25
01-18-2020 11:25
@Halfdozen Welcome to the Community. Thanks for the details mentioned.
I've moved your post to this thread because it's more related to the topic. In this case, I would like you to try the troubleshooting mentioned above. If you're still experiencing the same, please provide me with a screenshot of what you're seeing.
Keep me posted.
01-18-2020 17:37
01-18-2020 17:37
01-18-2020 18:11
01-21-2020 16:54
01-21-2020 16:54
@Halfdozen Thank you for getting back. I appreciate the screenshot shared. Could you confirm that the phone you're using is listed here?
Keep me posted.
01-21-2020 17:26
01-21-2020 17:26
I have the IPhone XS with iOS update 13.3
09-05-2020 07:04
09-05-2020 07:04
My weight changes on its own as well. Mathematically, appears to be consistent with the idea that somehow it is converting pounds to kgs but my advance settings are set to pounds. Help!!
10-02-2020 04:08
10-02-2020 04:08
I’m 10st and my Fitbit keeps changing to 38-40st pretty much every other day 🤬
10-28-2020 01:20
10-28-2020 01:20
Any news on this? My app keeps changing the measurement units from Kg to Lbs every couple of days.
11-08-2021 20:17
11-08-2021 20:17
Mine is EXACTLY the same. Actual weight 140-145 but always changes to 314.2.
