03-16-2022 05:00
03-16-2022 05:00
I was wondering how you are supposed to make you weight private on your profile.
You can hide height, age, sex, birthday. But there is no setting for weight. I still want to log my weight on the app but don't want anyone to be able to view it.
03-16-2022 06:02
03-16-2022 06:02
I don't think weight is visible to anyone else in any case, unless they happen to see it on your wrist with some models.
03-16-2022 07:09
03-16-2022 07:09
When you are altering your privacy settings on the dashboard there is a "profile as viewed by:" and then the options are anyone, friends and you. As I said you can hide each one of the things above except weight which when viewed as a friend, is still there.
03-16-2022 07:33 - edited 03-16-2022 07:35
When you click on 'Profile as Viewed by Friends', do you see your weight? I don't.
Also note Privacy Settings > Graphs > weight graph which you can set as private.
And if you have any "friends", can you see their weights? I don't see the weight of any of my "friends".
03-16-2022 08:45
03-16-2022 08:45
I've got those settings selected already and when I view my profile as viewed by friends I do still see my weight.
I don't see the weights of any of my friends though so maybe it is a glitch.
03-17-2022 04:06 - edited 03-17-2022 04:09
@MattDarlow I compared the Privacy settings on the web dashboard and the mobile app. There is a setting on the mobile app that isn't on the web dashboard. Tap on you profile picture on your mobile app > scroll down to the Social & Sharing > Privacy > set Weight to Private and tap on Save.
I don't know why you this choice is missing from the web dashboard.
Laurie | Maryland, USA
03-23-2022 09:48
03-23-2022 09:48
FWIW, I just clicked through to your profile and your weight is not visible.
