11-06-2022
06:40
11:46
AndreaFitbit
11-06-2022
06:40
11:46
AndreaFitbit
I can not change the time on the fitbit watch after DST ended on versa 2.
Moderator edit: format and label.
11-07-2022 04:52
11-07-2022 04:52
@10bigred Your Versa 2's time is synchronized with the time on your smartphone. Just give it some time after the end of DST or synchronize manually in the Fitbit app.
11-07-2022 04:52
11-07-2022 04:52
11-07-2022 07:48
11-07-2022 07:48
Same problem. Went into my Dashboard, found the Control gear icon (top right), clicked Settings. Clicked on Personal Info & scrolled down to Time Zone. Mine was wrong so I reset it then restarted my Versa (by holding the left & bottom right buttons down until it showed the change icon). That fixed it.
Best Answer11-07-2022 09:41
11-07-2022 09:41
Same problem here and I've restarted after checking my time zone setting and re-synced multiple times. My phone is right time and the versa is still an hour off. It's making me crazy as it's been half the day already reading the wrong time. I'm not being very patient.
Best Answer11-10-2022 06:14
11-10-2022 06:14
Talahthas, yes thank you. Finally got it synced up to correct time.
