04-19-2020
17:05
17:08
04-19-2020
17:05
17:08
I have a flex 2 that I got 5 years ago. I haven’t used it in 4 years. I don’t have the app that came with it. Can anyone tell me what app I need?
Thanks
04-19-2020 18:43
04-19-2020 18:43
use the regular fit bit app...
Best Answer04-19-2020 18:57
04-19-2020 18:57
Hi @Anna-Lysse here are the directions to set up, which gives the links you need - click to view. You'll want to be sure your Flex 2 has the latest firmware and your phone is compatible. If it's been sitting for four years, with a dead battery, you may need to restart it a few times to jump start it.
Best Answer04-20-2020 10:11
04-20-2020 10:11
