07-03-2014
		16:18
		16:59
		07-03-2014
		16:18
		16:59
Has anyone had an issue with the battery not charging on the Flex?
		07-23-2017
		16:39
		13:24
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		07-23-2017
		16:39
		13:24
@Petrolia55 thanks for getting back to me and for clarifying this info! I will then forward your inquiry to our Support Team. Keep an eye on your inbox for further instructions!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
07-24-2017 08:25
07-24-2017 08:25
It seems to be a faulty product. I had one that lost charging capability after about 8 months. To Fitbit's credit, the company replaced it, but the replacement didn't fare much better. I took good care of it and followed all the instructions for recharging, but the second one also died. Since I didn't like wearing both a watch and a Fitbit, I bought the combo version in January (call me crazy for trying the same brand). So far, so good.
 Best Answer07-25-2017 20:53
07-25-2017 20:53
 Best Answer11-09-2017 07:56
11-09-2017 07:56
I am not much when it comes to technology. What do you mean that the flex with not recover from low discharge or critical battery stage? Is it now dead? My flex is not charging, there are no light nothing. I tried all of the cleaning and troubleshooting options. It was a gift. I am not sure if can get proof of purchase.
 Best Answer11-09-2017 15:41
11-09-2017 15:41
 Best Answer11-09-2017 18:54
11-09-2017 18:54
 Best Answer11-10-2017 03:18
11-10-2017 03:18
		15:29
		13:25
		12-03-2017
		15:29
		13:25
Hello there guys!
@Posh101 @Petrolia55 @connorgram Hope you're doing great!
@Posh101 thanks for attempting the troubleshooting steps beforehand. If your tracker isn't properly responding then I shall send this info to our Support Team for a deeper look into your tracker's behavior. Keep an eye on your inbox for further instructions. ![]()
@Petrolia55 thanks for your input! What tracker did you purchase this time? Share with us! ![]()
@connorgram What tracker do you own? I'm a little confused here since Flex isn't designed with a clock capable screen. This one works a little different.
 Hey, have you tried restarting your tracker? Do let me know, I'll be around!
12-04-2017 04:52
12-04-2017 04:52
		13:52
		13:25
		12-06-2017
		13:52
		13:25
@Petrolia55 It's nice to hear back from you! I suggest checking out this page with more info about Fitbit devices, you can compare them and choose your favorite.
Hope this helps. Feel free to post back!
12-19-2017 16:29
12-19-2017 16:29
Found this forum when a 2 year old fit bit flex battery would not charge. Tried the online chat and they suggested cleaning the contacts with rubbing alcohol and cotton swap (q-tip)...heres the link we used -- https://help.fitbit.com/articles/en_US/Help_article/2005c=Topics%3ABattery&l=en_US&fs=Search&pn=1
Worked for me so hopefully it does someone else.
		12-21-2017
		17:23
		13:26
		12-21-2017
		17:23
		13:26
@GVelez thanks for stopping by and sharing this information with the rest of the Community! This is definitely going to help other users with the same inquiry. Just one thing, the link you shared seems to be broken. I found there other two articles with the info you were describing:
I really hope this helps.
01-22-2018 01:45
01-22-2018 01:45
Here is how to fix Battery Plugged in Not Charging Problem In Windows 10
1- Right click on Windows icon to expand out its context menu. Find and click on the option entry named Device Manager as shown below.
2- A window named Device Manager opens up. Expand the entry named Batteries by clicking on the side arrow associated with it. As next, right click on Microsoft ACPI-Compliant Control Method Battery and click on the Uninstall option.
3 – Now Shutdown your laptop.
4 – Now, remove the Battery manually and then unplug the Power Adapter from your laptop.
5 – Press and Hold the Power Button for full 1 Minute
6 – Now, again reinsert the Battery and connect the Power Adapter to laptop
7 – start the system again. the message “Plugged In Charging” message will be there waiting for you.
Source:- https://merabheja.com/fixed-battery-plugged-not-charging-problem-windows-10/
01-24-2018 14:36
                              01-24-2018 14:36
@josefin1 Thanks for sharing this workaround with the rest of the thread! This is what the Community is all about: sharing knowledge and best practices. Keep it up!
On a different note, I'd like to invite you to our Lifestyle Discussion Forums. There are lots of interesting topics; my favorite is "Eat Well". Who doesn't love food? ![]()
I really hope to see you around more often!
12-02-2018 08:33
01-22-2019 05:16
01-22-2019 05:16
Im still having the same issues. I love having a fitbit but hate my flex.
For example I spent 20 minutes this morning trying to wedge something in my charger so it would charge but seems it's useless so now I go without my Fitbit yet again.
02-05-2019 04:45
02-05-2019 04:45
My Fitbit battery is not charging after I was not able to recharge before it got drain. Can you pleas help me with my problem..
07-14-2020 10:02
07-14-2020 10:02
i'm trying literally everything in order to solve this problem.
It's clear that there is some kind of issue with the pins for the charging phase.
Contacted the support and they answered me that it's possible to have a discount for a new fitbit product.
Still, the idea is to use my actual fitbit flex, not a new one!
At first adding a paper-layer within the charger in order to push down the flex worked, now it's not working anymore.
Let's see.
