09-01-2020 06:43
09-01-2020 06:43
I have a flex fitbit. The battery will not charge. When I put it in the charger lights 1 & 3 flash and then lights 2 & 4 flash. Has anyone else had this problem?
09-01-2020 08:38
09-01-2020 08:38
Hi @debkhughes you try a restart to the Flex? From the description of the lights, your Flex is in sleep mode. You might want to look over the Flex manual and related help articles - click to go there. Be sure you have the latest app for the mobile device you use and the latest firmware for the Flex, which is 7.8.8
Best Answer10-09-2020 15:14
10-09-2020 15:14
I get only one light. then it goes dark. have tried all charger connectors that used to work and none charge it. What would happen if I plug it into my desktop tower?
Best Answer10-09-2020 22:38
10-09-2020 22:38
Hi @Mary19701974 I used to and still do, charge my Fitbits by plugging it into the usb port of my computer. Before you do, make sure there isn't any dust that might be preventing proper contact while on the charger. Also, age can be a problem, too. Sometimes these devices die. Try restarting your Flex a few times and see if any of this helps.
Best Answer10-10-2020 05:23
10-10-2020 05:23
