04-05-2020
08:10
17:08
04-05-2020
08:10
17:08
I wore the band to walk and at the end of the walk, I checked the lights on the band and 3 out of 5 lights glew indicating that I did not achieve my target. I reached home and tried to sync to the app to know the steps. The abnd then got reset and the band showed me 75steps which is disappointing as I am trying to know and maintain the trend. Please help here
Hello @Ayisha_walk, welcome to the Community!
Let me help you out with your missing data from your Flex 2. So that I may better assist you, please let me know:
- How often do you sync your Flex 2? Note that when you don't sync often and the battery drains out, the tracker may loose the correct date and once you sync again, the information may be saved on incorrect dates.
If this isn't the case, I'd recommend you to restart your tracker and see how it behaves on the following days. I do recommend to sync it daily.
Keep me posted.
