11-13-2020 12:10
11-13-2020 12:10
I am pairing a different flex 2 to my pixel 3 app account because I misplaced my old one. At first I couldn't get past the searching phase, it would find the device and then close without finishing the sync. I reinstalled the app and have restarted my phone. Now I can get to the "double tap to finish setup part" but my double tapping doesn't register anything and after multiple attempts I get the "not working?" tips which I have followed and it didn't help.
I attempted to reset my fitbit but pushing the button on the charger 3 times in 5 seconds with my pebble inside it does nothing. My fitbit won't flash all the lights like it's been reset.
I am so close to getting this setup done, why won't the double tap register and finish device setup?
11-24-2020 16:54
11-24-2020 16:54
same issue with my flex 2 on a pixel 3. was working fine up until a couple weeks ago. not sure if it's a compatibility issue with the pixel 3 or planned obsolescence
 Best Answer11-24-2020 16:57
11-24-2020 16:57
partner is also having the same issue with their flex 2 and pixel 3
 Best Answer12-05-2020 17:28
12-05-2020 17:28
I'm having the exact same issue on my pixel 3XL.
 Best Answer12-16-2020 21:05
12-16-2020 21:05
Has anyone found a fix for this issue? This started for me a couple of weeks ago and I've been unable to resolve. Pixel 3xl, Flex 2. Tried all the troubleshooting steps.
 Best Answer12-17-2020 06:59
12-17-2020 06:59
 Best Answer12-22-2020 11:51
12-22-2020 11:51
Let's be honest here, Flex and Flex 2 are old devices and these glitches are for us to UPGRADE. I have a brand new Flex, it synced beautifully but two days later not so much. I am beyond PISSED.
 Best Answer01-14-2021 19:37
01-14-2021 19:37
I spent FOREVER yesterday trying to get this to work (after not using my tracker for ages). So frustrating!
Has anyone found a workaround for getting the Flex 2 to work with the Pixel 3xl? I see that the mods are ignoring this thread this far - nice! 🙄
 Best Answer01-15-2021 14:28
01-15-2021 14:28
 Best Answer06-19-2021 15:50
06-19-2021 15:50
Ok, so I was distracted while going through set up and waited a lot longer. For some reason, it automatically brought up a different bluetooth pairing screen. A few seconds later, my phone's bluethooth pairing request popup appeared. I told it to pair and allow contacts and all that. Then it went back to the "double-tap" screen, and it worked.
