02-28-2015
10:15
10:10
ManuFitbit
02-28-2015
10:15
10:10
ManuFitbit
Hi there- I've lost my fitbit but it is still syncing to my phone. Does anyone have any tips on how to narrow down where it is? Thanks!
Moderator edit: clarified subject.
05-14-2019 14:46
05-14-2019 14:46
06-30-2019 16:38
06-30-2019 16:38
THANK YOU!!!! After searching for 3 hours, I purchased the app and found my fitbit in 90 seconds!!
07-01-2019 01:43
07-01-2019 01:43
07-18-2019 08:27
07-18-2019 08:27
How can I do this? Frustrated trying my Fitbit. It says that it is synced and connected
07-18-2019 10:21
07-18-2019 10:21
07-18-2019 10:24
07-18-2019 10:24
07-18-2019 15:03
07-18-2019 15:03
07-18-2019 15:12
07-18-2019 15:12
So pleased you’re sorted. 🙂 Lost a set of keys here - sadly nothing to track me to them!
07-23-2019 01:19
07-23-2019 01:19
Your suggestion saved the day!
I had misplaced my Charge3 and searching for it manually didn't result in my finding it. I installed the BluetoothFinder app, but it was basically useless. Then I tried your method and lo and behold! -- after turning off all fans and other noisemakers, and finally getting the alarm set far enough in advance, I was able to hear the vibrating and track it down.
One bit of advice: it might take anywhere between 30 seconds and 2 minutes for your phone to "save" the alarm to the FitBit, so set it at least 3 minutes ahead of your present time. If the "saving" is still in progress when the minute for the alarm arrives, it will treat the alarm as if it was set to go off tomorrow.
09-15-2019
06:30
07:31
JuanJoFitbit
09-15-2019
06:30
07:31
JuanJoFitbit
Thank you for mentioning the lower number.. not sure how the app works , Light Blue, but still trying to find my fit bit.
FINALLY. An app that worked!!! THANK YOU> it was worth the $, so I'd stop looking for it. Blue light, didn't work right for me... whew... now I can harge it and buy a new band!! thank you.
Moderator edit: merged reply
10-19-2019 10:29
10-19-2019 10:29
How to sync my Fitbit I can’t find it and I have it on my phone app and when I am in the app I don’t how to try and sync
10-19-2019 11:45
10-19-2019 11:45
Hi -
I'm not sure I understand the precise position but you need to act fairly quickly before your Fitbit runs out of power.
If the Fitbit app on your phone is synced with the Fitbit watch and it's nearby it ought to identify it as it'll be in range but it won't tell you where it is. That's where the other app I mentioned comes in. It will identify all devices nearby where Bluetooth is switched on. It may not pick it up straight away - walk slowly around your home (or wherever you suspect it is) and eventually it should pick it up. As you get nearer the display will increase or it'll decrease if you move in the wrong direction.
Worked well for me and seemes to have done for others, so good luck.
10-19-2019 17:01
10-19-2019 17:01
Kay31, Sorry, don't understand what you're asking.
Is your Fitbit misplaced, or are you saying you can't find the sync command in your phone app.
If you can't find the sync command in the app, please open a new topic. This topic thread is about finding a lost Fitbit.
If the Fitbit is lost, then, I don't understand why you're trying to sync it. First find the Fitbit using one of the methods in the previous entries. Install a fitbit or bluetooth device finder app on your phone. Quickly, before the Fitbit runs out of power.
06-07-2020 10:18
06-07-2020 10:18
The Android Finder link you posted doesn't work
06-07-2020 10:36
06-07-2020 10:36
06-10-2020 12:24
06-10-2020 12:24
08-21-2020 06:40
08-21-2020 06:40
Thank you! You made my day ^_^
08-05-2021 18:01
08-05-2021 18:01
How did you find your Versa?? I've been packing all day. And I just noticed it was gone. I used the app that when I chated with someone from the app gave me. But I never seen versa. But I just turned on notifications and still can't find it. I've opened up 7 boxes. Nothing. Can you please help me?
08-05-2021 20:31
08-05-2021 20:31
01-24-2022 11:24
01-24-2022 11:24
Do you know how to find a Fitbit out of charge? Anyway at all?
