11-14-2016
18:10
16:59
11-14-2016
18:10
16:59
I have noticed in the past couple of days that my FitBit is not calculating my sleeping hours correctly. One day i went to sleep from 8:49pm to 7:10am and it says i only did 7 hours and 25 minutes. Then last night i went to sleep at 10:51pm and woke up at 4:45 am and it said i only did 3 hours and 42 minutes. Obviously numbers are not correct. What should i do?
@gcherbony Welcome to the Fitbit Community! I recommend performing a restart on your Flex to prevent any wrong sleep tracking from happening again.
Also, what @samnf2000 was saying is correct. You can try changing the sleep settings for it to not be too sensitive. Try using the normal sleep setting.
By the way, it's great to see you in the Fitbit Community! @samnf2000 ![]()
Keep me posted!
Best AnswerHow do I reset a charge 2? This started when I downloaded the latest update for my iPhone 😞
