07-01-2016
11:33
16:59
07-01-2016
11:33
16:59
@Taushiamarie welcome to the Community! It's great having new faces.
Let's work this out! Also, make sure that you have only one tracker paired to your account (MobileTrack counts, and this should only be paired to your account if you didn't have any Fitbi tracker). Also, I recommend restarting your tracker by doing the following:
Actually your Flex, auto detects sleep logs. To track your sleep with Fitbit Flex, simply wear your tracker to bed. When your Flex syncs in the morning you'll see last night's sleep stats on your dashboard. If your tracker is stuck in sleep mode, please tap your Flex rapidly for one to two seconds to exit sleep mode. Upon exiting sleep mode, your Flex will vibrate and display flash all five LED indicator lights several times, and then display a spinning light pattern.
Now, I've found this idea to add Pregnancy and Nursing settings. Add your vote and your comments so it can gain momentum!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
MIriam,
just to be clear, when my fitbit is in "sleep mode" it will record sleep but NOT steps? the reason i asked is that i'm looking at the data from my fitbit (i downloaded it) and i can see periods (they are infrequent but they exist) where sleep is being recorded but no steps (i.e. 0 steps) and i also see periods where steps are recorded but no sleep. the 2nd makes a little sense since i sometimes charge my watch at night but the 1st is confusing UNLESS my watch got stuck in sleep mode and while it was in sleep mode it recorded sleep sessions but no steps. Thanks.
