02-07-2020
22:34
16:54
02-07-2020
22:34
16:54
I just found my old fitbit flex from 2014-2015 (around that time) and when I try to double tap the screen or any of the fitbit flex it will not respond, the only time it responds is when it is plugged into the charger and its got a full 5 lights flashing indicating it is fully charged but again when I take it off the charger it does not respond. I have tried to reset the flex but that has not done anything either. Anyone have any ideas or do you think it is just too old that it has stopped working. Thanks for your time.
02-07-2020 23:41
02-07-2020 23:41
Hi @Aussie_Elite when the battery has been dead for that long, I really doubt it will come back to life. Keep restarting it a few times to see if that helps revive it. There may have been a firmware update on the Flex, so check for that. The Flex was replaced by the Alta series, which has been replaced by the new Inspire family of Fitbits. I started out with a Flex and it lasted about two years. The oldest Flex I've seen mentioned on the forums lived to four years.
Best Answer02-07-2020 23:41
02-07-2020 23:41
Best Answer04-26-2020 22:57
04-26-2020 22:57
I'm having the same problem in trying to revive a really old Flex. Were you able to bring it back to life? I tried restarting a few times, same issue. It does not respond as soon as I take it off the charger.
Best Answer04-26-2020 23:00
04-26-2020 23:00
Hi @WAUser the original poster hasn't returned in two months,so we don't know what happened. All you can do is the restart procedure. Be sure you have the latest firmware and app. Mine died after two years. Sometimes you just can't revive them. Sorry. However, now is a good time with Mother's Day sales going on to pick a new Fitbit.
Best Answer04-27-2020 09:24
04-27-2020 09:24
Thanks Odyssey13. I tried the restart a few times, but no luck. It dies as soon as it's taken off the charger 😞
Best Answer04-27-2020 09:26
04-27-2020 09:26
Sounds like it's dead @WAUser . My own Flex did the same after several bouts of restarting and dying.
