10-21-2020 07:52
10-21-2020 07:52
I had problems with my Fitbit Flex and iPhone 5 not syncing as of 2 days ago. This version of Fitbit is no longer being supported. Call 877-623-4997 and get a 35% discount off a newer version. I got Fitbit InspireHR. Hope this helps.
10-21-2020 14:30
10-21-2020 14:30
Not sure who gave you this info, but I called them and got mine back up and running per my post another thread:
Call them. 877-623-4997. I thought I tried everything and it didn't work. Tech support simply had me "add new device" and now I'm back in action. Or you can try that option for yourself.
Best Answer10-21-2020 14:34
10-21-2020 14:34
I just spent a bunch of time trying all the recommendations to no avail but tech support got me sorted out rapidly. Just call.
Best Answer10-22-2020 09:46
10-22-2020 09:46
Exactly. Tech support was great, even for the good old Flex! Just one more thing..after deleting & reinstalling Fitbit in your app. do restart your phone once everything is done and Fitbit tracked is back on. None of your activity data is lost.
