04-08-2024 05:10
04-08-2024 05:10
How do I set steps on the fitbit because it shows calories burned. That is great but I would like the steps counter. Thanks!
04-08-2024 07:10
04-08-2024 07:10
Hi @Chartries check to see if you set it up correctly - click to read instructions. If you did, then be sure you made steps your main goal - click to learn how.
