01-29-2016
21:08
16:59
01-29-2016
21:08
16:59
Wasted hours trying to sync. Error messages and no luck. What a waste.
Moderator edit: Edited title for clarity
01-30-2016 05:21
01-30-2016 05:21
Restart
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-restart-my-tracker/
Try it a couple times
Wendy | CA | Moto G6 Android
01-30-2016 10:19
01-30-2016 10:19
When I have synching issues I do two things which normally help, the first I turn off wifi on my phone and then turn it back on and then I disable and enable bluetooth. Not techy or scientific just seemed to have helped when mine stopped synching on new years eve. I hope you get it resolved, I agree it would be a shame to give up on something you obviously have been using and hopefully enjoying for two years.
Elena | Pennsylvania
Best Answer01-29-2016 21:12
01-29-2016 21:12
Normally user error. Can you give us a clue as to what is wrong? maybe we can help?
Best Answer01-29-2016 21:19
01-29-2016 21:19
01-30-2016 04:14
01-30-2016 04:14
Have you tried restarting the tracker? Have you contacted support? It would be a shame if you give up on Fitbit after 2 years of enjoying it.
Best Answer01-30-2016 04:24
01-30-2016 04:24
01-30-2016 05:21
01-30-2016 05:21
Restart
01-30-2016 10:19
01-30-2016 10:19
Best Answer01-30-2016 10:24
01-30-2016 10:24
07-16-2016 07:46
07-16-2016 07:46
Best Answer07-18-2016 10:31
07-18-2016 10:31
@Sarahtc Sorry to hear about the trouble with syncing. I recommend trying out these troubleshooting steps and then giving syncing another try.
If that doesn't resolve the issue, please answer the following:
Hope that helps out.
07-18-2016 12:51
07-18-2016 12:51
07-26-2016 10:25
07-26-2016 10:25
This has to be the worst app and sync crap I've ever used. The fitbit will not connect or sync properly, it keeps changing the time whenever it wants and it totally screws up my Windows App. Apparently according nto Fitbit support yu need to install then uninstall the app the reset the wifi, bluetooth, time zone..etc, etc... What kind of App requires 3 re-installs to even recognize this piece of junk???
07-26-2016 10:37
07-26-2016 10:37
Best Answer12-12-2017 19:12
12-12-2017 19:12
Totally random when it comes to synching, sometimes needs a restart.
Why location services are needed to be turned on to make it synch eludes me or were just wearing fitbits trackers so they can gather more data on us.
Piece of random **ahem**e.
01-13-2019 06:18
01-13-2019 06:18
I agree they are absolute crap. We are currently travelling through Europe, we are from Australia and my fitbit and my wife's fitbit will not synchronise. Why does it need location services? I am over having to restart my phone, delete the fitbit app and re-install, turning off and off the blue tooth, resetting the wifi connection.
Or the best one so far was the complete reset of the fitbit, that was some scary **ahem**. Hold button for 10 secs, stand on one leg and offer a virgin as a sacrifice (not really but was close, anyway I couldn't find a virgin in Australia)
We both have Charge HR's
Do not buy or waste your time with this junk
10-31-2019 19:06
10-31-2019 19:06
02-15-2020 13:07
02-15-2020 13:07
No one should have to make excuses and constant workarounds for this crap app. I think they stop maintaining the app for their older models because they want you to buy their new crap.
02-15-2020 13:07
02-15-2020 13:07
You are hilarious (normally user error) hahaha
11-07-2020 10:53
11-07-2020 10:53
User error are you serious??? Look at the reviews on Google and apple stores, look at people's comments.
I have never in my years of using tech had this level of problems and I had a Spectrum 48 k!!
10-16-2022 19:21
10-16-2022 19:21
Charge 4 has turned out to be a useless piece of **ahem**. It won't sync properly. It no longer shows sleep score and the clockface changes at random and the time zone is wrong too.
Last time I purchase anything from this company..
