12-16-2016
09:08
17:15
12-16-2016
09:08
17:15
Received my Flex 2 in November and it won't hold a charge for more than a day (two if I am lucky).
I have read through all these and still don't see a viable solution...
I haven't have alarms or all day sync on for some time and still no improvement in battery life.
Thoughts,, anyone?
12-17-2016
02:00
14:04
MariamV
12-17-2016
02:00
14:04
MariamV
Hello, you have a faulty Fitbit. Get in touch with them direct and they
will replace it for you.
They did with me and I see no reason why they wont for you.
*Kind regards*
Moderator edit: format
Hi there @aeschine1963. Good to see you in the Fitbit Community! 🙂
I'm sorry you're having problems with your Flex 2 😕 The battery should last at least 5 days with a regular usage. Since your your tracker is draining in less than two days, this is not how it should be. I would recommend fully charging your tracker and once it's ready, start using it as you would normally do making sure you sync it constantly. That way when the battery dies, you can get in touch with the Support Team as @embejemi suggests and they will be able to see in the logs how the battery is behaving and based on that, they will be able to help you out with this.
Let us know how it goes and I'm moving your post to the Flex 2 board for categorization purposes.
Best AnswerI began using my Flex 2 about 5 weeks ago (previously using a Flex). I am pleased with the Flex 2, but over the last 2 weeks I have, also, begun experiencing a complete loss of power over a 2-day period. Today, I have charged it fully, and I will ensure that it gets regular usuage and syncing over the next 2 days. If the problem persists, I will contact Fitbit Support. Thanks FerdinandFitBit for the advice and guidance.
Best AnswerEmail fitbit they are very good with customer service they will probably send you a new one.
Mine now goes 3 days with alarms and syncing. I let it run right out then charged which helped me get to the 3 days of charge ??
Best AnswerJust received my Flex 2 a few days ago but having battery issues from day one. I only getting about 6 hours per charge, even after turning off all-day sync, notifications, silent alarms, etc. if I've tried using different chargers, different outlets, using the USB port on my pc, none of which have helped. Also tried restarting, to no avail. Is there anything else I should try or should I give up and call Fitbit? I'm excited about the motivational aspect of Fitbit but this is soooo frustrating! Thanks.
Best AnswerGot my flex 2 as a gift Thursday and charged completely wore all day friday woke up this morning with 2% battery..
Best AnswerJust advising all the folks here that I have, routinely, RECHARGED my flex 2 every evening at dinnertime, now, for 3.5 years, and it is still working fine. YES, it is somewhat inconvenient to do it EVERY DAY, but it works and it works well. Just establish the habit and DO IT. Thanks.
