Hi @singhmani It sounds like it may be dying. How old is it? Try restarting it several times and see if that helps
Helen | Western Australia
Best AnswerUnfortunately it is probably dying and if the restarts dont help then there is nothing you can do. If you are in Europe then if it is just under 2 years it will still be covered by warranty, but anywhere else the warranty is only a year.
