02-07-2020
08:17
17:08
02-07-2020
08:17
17:08
Today I received a message with the heading :
Update the fitbit app
Then , further down the page:
This version is no longer compatible with your flex2. Your device may not be able to connect with the app until you update.
At the bottom of the page 2 options:
Update app or Maybe later
When I select Update app I am taken to the app update page which requires me to select Open. When I select Open I am taken bak to the Update the fitbit app page. This is extremely frustrating. Any answers?
Hi @romasingleton might be helpful to know which phone and operating system you're using.Let us know.
Best AnswerThank you for your response. Glad, but mystified, to say that it has now returned to normal!
Best AnswerDeleted and reinstalled software and that helped. Had to also turn Bluetooth on and off once reinstalled.
Best AnswerMy Fitbit 2 stopped syncing 2 days ago although fully charged. Tried all recommended routes then uninstalled App and reinstalled. Set up will not complete????
