01-22-2021
01:52
14:17
01-22-2021
01:52
14:17
Hi. I haven’t used my flex 2 for several years. I have tried to charge it but it just has one light. I have updated which completed but still no charge so can’t set it up. Any ideas. Many thanks
01-26-2021 23:08
01-26-2021 23:08
Hi @Zaza1103 Unfortunately Lithium ion batteries do tend to deteriorate over time, especially if left with no charge. However before you give up hope try cleaning the contacts on the pebble and the charger with rubbing alcohol and try a different power point or USB slot. I don't hold a lot of hopeful it, but worth a try
Helen | Western Australia
01-27-2021 04:07
01-27-2021 04:07
