01-23-2021
12:24
14:18
01-23-2021
12:24
14:18
My fitbit will not sync with my phone app. It is coming up with device not found. It was syncing amd working with no issues on Tuesday and before.
I have followed all the suggestions, turned the Bluetooth on and off, deleted the app and reinstalled it, restarted my device, checked my fitbit and it is charged.
Can anyone advise / suggest what I should do next?
Thanks
@Querty1 , I've had the same issue with my @Flex2 , and it started Saturday. Won't show up via the site, either, though it says last sync was yesterday at 1:14pm. I've run through uninstall (both the fitbit, flex2, and bluetooth) on every device, and restarted, but to no good. @Fitbit could you please help with this? I realize there is "no support" for Flex2 (as it has been discontinued) but there should be a response from Fitbit when a product no longer works properly. Thank you.
h
