05-17-2022 05:01
05-17-2022 05:01
Hi @Hcortez Does the Flex 2 vibrate at other times? For an alarm for example?. If it isn't vibrating at all try restarting it a few times and see if that gets it going. If it doesn't it is probably the vibration motor and sadly that can't be fixed. Restart your Tracker
If it is just notifications that are not working try THIS Help Article on notification pro lems.
Helen | Western Australia
