08-16-2016
18:43
16:59
08-16-2016
18:43
16:59
Hi - Hoping Fitbit Support reads this message.
I haven't been using my Fitbit for a few months but decided to refocus and charged my Fitbit Flex last night. All geared up today and worked out but it shows zero steps registered (even though I have Synced). The only difference is I am using a new computer but I still have my active website. I placed the dongle in this new computer - do I need to do something else? HP Windows 10. Even when I check on the actual Fitbit Flex Wristband it shows I have less than 2,000 steps (likely zero).
It always worked on my iphone as well (which has not changed). The dashboard says zero steps as well.
Help
Sherry
10-29-2017 11:45
10-29-2017 11:45
so thi is whats happening
im plugging the charger into the usb on my laptop, sticking a pin in for 4 seconds, lights turn off but within 3 seconds the lights are going up and down again (oncce i put the tracker back in the wristband)
so i dont know what to do
10-29-2017 12:40
10-29-2017 12:40
@suemacfit I hope you're doing well! I replied to your other post here which is about the same topic. Please try the workaround I left there. It should definitely help you out with this!
Try that out and let me know how it goes!
11-05-2017 21:25
11-05-2017 21:25
I followed your instructions but like other users are saying, it does not work. The tracker (flex) starts back with 2 led lights dancing left/right right after I take it out of dongle. What else can I do?
FWIW, I was trying to upgrade firmware from android phone and then when this problem started.
11-11-2017 16:49
11-11-2017 16:49
I'm still having the same problem.
01-07-2020 10:39
01-07-2020 10:39
I removed (deleted) my Fitbit from my device and reconnected it (added it back as a new device ) and it worked ! Hopefully it helps you as well .
01-13-2021 13:33
01-13-2021 13:33
The lights went off, then 6 lights came on and it went back to the roaming lights from left to right. What should I do?
01-13-2021 13:35
01-13-2021 13:35
Sorry, I meant 4 lights came on and it went back to the roaming pattern
01-21-2021 20:09
01-21-2021 20:09
Hey!
It's nice here, I'd like or go for charge 4
01-23-2021 18:19
01-23-2021 18:19
Didnt work for me but thanks anyway.
