So my flex has stopped flashing when charging, I even got a new charger to try today. The app says it is at 8%/dead however it’s on and recording steps. I have tried resetting it through the charging cable but no change. Both the Fitbit app and the website say the same. Many thanks
Hi @SarahMcna,
Are you sure that it's secure in the cradle? You should hear a soft click once it's in. Without that click, the device isn't getting a secure connection, and hence why you may not see the flashing lights.
one cruise ship at a time!
Best Answer@SarahMcna the 8% was just what Fitbit last synced, so it'll always show this until it's removed or synced. I'd suggest cleaning the charging contacts with 99% isopropyl alcohol.
Best AnswerIt’s syncing everyday, so steps, sleep etc updates but still shows battery at 8%. I haven’t tried alcohol on the contacts but I have tried cleaning them. I will try the alcohol if you think this will help?
Best AnswerYes it’s clicking to the cradle, I’ve tried 3 of them. I think it must be charging as the app has shown 8% for a week now but has recorded steps all week. It’s just not changing on the app or lighting up, although it’s lights up according to the steps each day.
Best Answer@SarahMcna Yes, I believe it may help, or I wouldn't have recommended it 🙄 Good luck!
Please share with the community afterward if this helped to resolve your issue. Thank you.
