The syncing stopped working on 20th December 2021. I wore Fitbit for 5 years and have no problem. Until I got COVID means not wear Fitbit for two weeks. Since I recovered I can’t get Fitbit work again I tried everything by reading instructions on Fitbit and google. My Fitbit is full charged my Bluetooth have Fitbit showing Connected. The syncing bit on Fitbit always cut short every time I touch it and wait then it stopped short. I noticed my Fitbit vibrates sometimes since 20th Dec. I believe I’m not only only with the problem.
Hi @SunsetRunner First I'd suggest you try restarting your tracker several times Restart your Tracker
If that doesn't fix the problem, try the suggestions in THIS help Article on syncing problems.
I really hope something there fixes the problem for you.
Helen | Western Australia
Best AnswerIf you tried all the suggestions in the help article then the Flex 2 might be dying, but perhaps contact Customer Support before you give up on it and see if they can help you. Good luck
Best AnswerIt’s working!! Thanks to Mum. I told her abt the issue I’m having and she went straight online to find the solution and found what I haven’t tried before! It wasn’t in Fitbit guide unless I overlooked.
So meant to say what I’m suppose to do. Remove device from Bluetooth settings on iPhone. Then go to Fitbit app and tap on notifications. A message appeared that I not seen before, ask me to pair and click and all’s set! So simple!
