04-17-2020
11:37
16:54
04-17-2020
11:37
16:54
So I have a generic charger that I bought off of amazon and I’ve been trying to reset my Fitbit flex and later found out that my charger does not have the hole to reset.. so how do I reset it now without the charger.?
I'm afraid there is no way to restart it without a charging cable that has the reset button. Unfortunately, Fitbit no longer sell them. Your best chance might be to find a Fitbit original charger on eBay (or similar)
Are you sure you need to reset your Flex? What issue are you having?
