10-01-2016
06:52
17:15
10-01-2016
06:52
17:15
I want to purchase one but not if it has a tendency to fall off my wrist like my Charge. Have you changed the clasp system?
10-01-2016 07:41
10-01-2016 07:41
Have had mine for nearly a week and my first impression is that the clasp is very secure.
To be honest, it takes a decent amount of effort to get it off.
10-01-2016 09:01
10-01-2016 09:01
I agree, it takes a fair amount of effort to unclasp it. Also, the band doesn't extend past the clasp much, so it's almost impossible to catch it on something, and have it unclasp and fall off. Seems very secure to me.
10-01-2016 07:41
10-01-2016 07:41
10-01-2016 09:01
10-01-2016 09:01
10-02-2016 07:46
10-02-2016 07:46
Best Answer10-03-2016 11:05
10-03-2016 11:05
I concur with the others. I've not had any issues with mine coming unclasped. It is actually a little difficult to take off, but since I only do take it off once every day or two, I'd rather it be that way.
10-04-2016 06:03
10-04-2016 06:03
10-10-2016 09:44
10-10-2016 09:44
As the others have said, the clasp does take some effort to undo. However, as added insurance, a 25 cent o-ring from the hardware should ease your concerns. For the Flex 2 a ring with a 3/8 inside diameter works fine.
10-11-2016 11:22
10-11-2016 11:22
Mine came off my wrist while I was sleeping. surprised me, because I have difficulty opening the clasp when I want to. If you google "band cover" you will find a small plastic loop that helps keep the band closed.
Best Answer10-25-2016 04:55 - edited 10-25-2016 04:57
I agree with all of you. I tried the new band + clasp mechanism of the new Flex 2 and I find it to be the most secure clasp designed by Fitbit so far.
Thank you for your feedback! Continue sharing your tips and experiences with this wristband
In addition, if you'd like to share your lifestyle and tips to reach a healthier and happier lifestyle, I invite you to take a look at the Discussions board.
Happy stepping!
Parliamo di calcio Qual è la tua squadra di calcio preferita?
.10-29-2016 02:19
10-29-2016 02:19
06-10-2017 15:02
06-10-2017 15:02
Lost my flex 2 as wristband fell off had it one minute went for a swim noticed it had gone nowhere to be seen really upset
Best Answer06-10-2017 15:49
06-10-2017 15:49
I bought two of the jewelry style bracelets so I could wear it with my business suits, dresses etc. Both have fallen off. The first time I found it in a parking lot on my way back to my car, someone had driven over it so the bracelet was toast. I took the fit bit counter out of the basket and put it in the other bracelet. I was traveling last week and noticed at the airport as I boarded the plane that my bracelet was gone. No idea where it fell off.
Anyone wanting the jewelry style for Flex2 is cautioned against it.
I also noticed with both bracelets that the basket that holds the fit bit often opened and the fit bit was on the verge of falling out.
Not the best design, won't be buying a replacement.
06-10-2017 16:19
06-10-2017 16:19
Best Answer08-29-2018 12:26
08-29-2018 12:26
How did you put on the o-ring?
Best Answer08-29-2018 12:30
08-29-2018 12:30
I have been using my flex 2 for little over a year and a half. The claps are secure but the little holes, on the other side started to break free. Any recommendations?
Best Answer08-30-2018 01:53
08-30-2018 01:53
You need to buy a new band.
Helen | Western Australia
01-15-2020 16:10
01-15-2020 16:10
My bracelet fell off while shopping. No hope of return :((. Clasp is not very secure. But I loved it.
