04-02-2020
10:10
17:08
04-02-2020
10:10
17:08
Anybody know of a great app to find my Fitbit? I’ve used several and only one is letting me know I’m close but doesn’t really zone in and I’m not able to find it.
04-02-2020 10:35
04-02-2020 10:35
Hi, @Amy70! Unfortunately, other than following the bluetooth signal, I'm not sure there's too much you can do. The only suggestion I can come up with is to set some alarms and see if maybe you can hear the tracker buzzing. Good luck!
MakMak | Community Council
04-02-2020 10:44
04-02-2020 10:44
Best Answer04-02-2020 10:51
04-02-2020 10:51
You can set silent alarms on the tracker. They will vibrate to wake you up. I'm just thinking that if it's in an area where it's not muffled or maybe sitting on a hard surface, maybe you'd be able to hear it buzzing.
Best Answer04-02-2020 11:55
04-02-2020 11:55
a field....:(
thanks for helping.
Best Answer09-22-2022 13:47
09-22-2022 13:47
Just found my flex by using “find my fit bit”!! The cost was 5.99 for the app. Which is cheaper than to 120.00 I was going dish out for a new device.
