10-01-2016 07:49 - last edited on 08-20-2020 17:15 by MatthewFitbit
I was just wondering whether it would be possible to pair my flex 2 with two different devices. I switch between an iPhone and an Android phone and it would be nice to do this. I was able to do this with my old Jawbone UP, but I remember some people not being able to do it.
Thanks.
10-02-2016 13:04
10-02-2016 13:04
@SunsetRunner Thanks for your help here!
@PDADoc As @SunsetRunner mentioned, you can use your Flex 2 on multiple devices! However, please keep in mind the following information:
1. It's recommended to use a device that's on our Supported Devices List.
2. You don't need to re-pair your tracker to each device. Simply log into your Fitbit account on each device and sync to see your stats.
3. If you have any issues syncing your tracker to one of your devices, take a look at this article to help!
Let me know if I can help answer any other questions!
10-01-2016 08:14
10-01-2016 08:14
You can pair it with several devices as long as they are supported. PC, iPhone, Android phone .... doesn't matter. Just add the apps to each and log in and sync with whatever is handy at the time.
10-01-2016 08:18
10-02-2016 13:04
10-02-2016 13:04
09-27-2017 11:39
09-27-2017 11:39
Yes, but how do I set this up?
09-28-2017 00:17
09-28-2017 00:17
Just download the app and log into your account on both devices and you can use whichever you want. I use a tablet and my phone. It is easy. I can sync on either and as the information is passed back to the Fitbit Servers it is instantly available on the other device. Come back if you have more questions.
Helen | Western Australia
01-07-2018 04:02 - edited 01-07-2018 04:03
I paired using my PC and syncing with my Charge 2 is fine. I also have the Fitbit app on my Samsung Galaxy S4 and this is always having problems syncing. All I see is a red exclamation mark. When I first bought the Charge 2 I tried setting everything up using the Android Fitbit app but found it was constantly failing during the add device process to pair with my Charge 2.
In the end I had to add my Charge 2 to my Fitbit app via the Windows app, which worked fine. When I logged into the Android app I saw my Charge 2 was present because I added it via the Windows app.
The problem I have now is that the only way to avoid syncing problems with the red exclamation mark indicating sync fail is to unplug my Bluetooth dongle from my PC. It therefore seems that the Fitbit app or the Charge 2 is incapable of supporting the situation whereby I have it paired not only with my PC but also with my smartphone. Could this be due to the 'Always Connected' option in the Android Fitbit app (this option does not exist in the Windows app)? Should I disable this if I happen to be at home with my smartphone and PC in Bluetooth range of each other with them both being paired to my Charge 2?
01-07-2018 04:29
01-07-2018 04:29
I am not sure, but it would be worth trying. And pairing does seem to change over time with updates to phones and trackers. I initially paired easily with two devices, then I could only pair with one, and now I can pairnwith the two again, but it is not as easy as it was initially.
Do you have notifications turned on? It seems when you do that the tracker 'prefers' to sync with this device (usually phone), so if the phone is anywhere near, the other device (in my case my tablet) wont sync.
01-07-2018 04:40
01-07-2018 04:40
02-19-2018 06:37
02-19-2018 06:37
Fitbit gets upset if it sees two active BlueTooth devices. If both are in the same house, you need to temporarily disable Bluetooth on one device. Personally, I can always sync on my iPhone, but my iPad won’t sync if my iPhone is here.
06-22-2018 19:45
06-22-2018 19:45
LenaFitbit, thank you for this reply.
I want to synch my Fitbit Charge 2 on an iPad and also on a MacBook Air.
I have it set up and working fine on the iPad already.
On the MB Air, can I synch just using the web browser (i.e. logging in to my Fitbit account using a web browser), or is it necessary to download and install the Fitbit Connect app?
Thank you for your help.
Joe S
06-22-2018 20:44
06-22-2018 20:44
@JoeS1 You need ro download the Fitbit Connect App. You cant sync from the website dashboard.
06-22-2018 22:42
06-22-2018 22:42
Thank you NellyG. Much appreciated.
Joe S
12-26-2019 06:43 - edited 12-26-2019 06:45
It doesn’t work for me I have always had the app paired with my iPhone, I just got an iPad and it tells me “No device found”. It shows it in my device list but I can’t access it. I’m afraid to try and remove and repair. Will it delete all my history on both devices?
12-26-2019 06:49
12-26-2019 06:49
No big deal. At night, I keep my iphone charging downstairs, and my iPad with me upstairs. Before bed, I swipe up on the iPhone, and disable BlueTooth. Then, the ipad syncs beautifully. In the morning, I turn bluetooth back on, on my iphone.
12-26-2019 07:01
12-26-2019 07:01
Peggie1956 - that works. I’ll just have a hard time remembering to do it. 😊
12-26-2019 11:24
12-26-2019 11:24
Oh! I DO KNOW that remembering to do it is the challenge! LOL
06-04-2020 05:35
06-04-2020 05:35
Thanks a lot, @Peggie1956 . Based on my experience this is clearly the actual answer sometimes, rather than the kind of vague talk-around based on the fact that it does sync _on the back end_ through whichever phone/tablet *does* manage to connect, which isn't what the question is really about.
06-20-2020 11:52
06-20-2020 11:52
Agree with Peggy1956. I have an iPhone 10 and a fifth generation iPad. Fitbit Ionic only pairs with one at a time and switching back and forth is neither simple or quick. Fitbit should work on this. The other answers in this thread seem unfamiliar with this problem, but Peggy1956 is totally right.
06-20-2020 12:02
06-20-2020 12:02
Thanks. I posted that solution over two years ago. It is still true, although the FitBit App is getting better at cooperating, sometimes, even if two BlueTooth devices are present.
