01-02-2021 09:00
01-02-2021 09:00
My Fitbit flex 2 has been flashing one pink light and white lights. I cannot find the reason for this. It is up to date. Other times it flashes one orange light and white lights. It says that it cannot sync, but it is syncing. Also I will go to bed with it charged at 100% and wake up with it at 75%. It seems that the battery is not lasting as long.
01-02-2021 11:03 - edited 01-05-2021 19:30
I solved the issue with the orange light. I was unable to locate silent alarms on my iPad, but looked on my PC and found a silent alarm set at the time the orange and white lights were flashing. I deleted that. Not yet able to resolve the pink light issue.
01-02-2021 09:14
01-02-2021 09:14
I don't know how to edit my own post but I wanted to add that My Fitbit is up to date. I have restarted it by putting the pebble into the charger and pressing it three times, allowing it to vibrate.
01-02-2021 09:55
01-02-2021 09:55
To edit, click the 3 dots near top right of text box.
If this is while on charger, each color change shows 25 % more charged.
01-02-2021 10:55
01-02-2021 10:55
Here's an article that tells about the lights:
https://www.wareable.com/fitbit/fitbit-flex-2-essential-tips-and-tricks
01-02-2021 11:01
01-02-2021 11:01
I tried those three dots but that it was not one of my options. Also she did not happen while I was on the charger and my concern is not the white lights, but the orange and pink lights. Thank you very much for your assistance.
01-02-2021 11:01 - edited 01-05-2021 19:23
That article does not mention the pink light or the orange light. Thank you.
