I 100% agree! What is this garbage? I can't see anything on my sleep tracking anymore! Putting my finger over it produces a stupid line that makes no sense at all. I can't read my sleep tracker! This is the only reason I use Fitbit. If you don't put it back the way it was which was easy to look at and to track everything then I will find a different company because Is such a bad change. If you change something you're supposed to make it BETTER!!!!
I totally agree with all of you. This new one is useless and stupid!!! I can't see the time of anything during my sleep, the sleep tracking doesn't have sense anymore as you cannot track it, and the main reason to use fitbit for me is the sleep tracking.
By the way, you could also create more new models as thin as the Flex 2, as they are the most comfortable to wear when you sleep. But I guess it doesn't matter, because if you are keeping this new visual for showing sleep, I will need to find another company where I can read properly my sleep.
I agree as well! The "new improved" sleep tracker is terrible and absolutely useless. The old way was far better and did not need to be upgraded. Please, please restore the former sleep tracker and then you will have have your customers who won't give their business elsewhere.
