09-09-2014
13:13
16:59
09-09-2014
13:13
16:59
My goal is 10,000 steps a day which is 5 miles. When I reach my goal my miles count is not 5 miles, I have to take 13,000 to reach 5 miles in order for the bar to turn green. How can I fix the steps and miles count.
01-27-2015 05:24
01-27-2015 05:24
Best Answer01-27-2015 05:27
01-27-2015 05:27
Best Answer01-27-2015 06:55
01-27-2015 06:55
Best Answer01-27-2015 06:58
01-27-2015 06:58
I would count any many inches bewteen each step!
like I have 36 inches bewteen each step
Best Answer01-27-2015 10:31
01-27-2015 10:31
Best Answer01-29-2015 15:52
01-29-2015 15:52
@betpchem wrote:I got the privacy error too. I bypassed it and copied the article. Here it is:
How do I measure and adjust my stride length?
Fitbit trackers calculate distance by multiplying your walking steps and walking stride length. Similarly, your running steps are multiplied by your running stride length. By default, stride length is determined using your height and gender. If you feel that your distance measurement isn't being accurately tracked, you may want to adjust your stride length:
Your running stride can be calculated the same way, only by running a known distance rather than walking.
- Go to a track or somewhere that you know the exact distance of.
- Count your steps as you walk across that distance, making sure you travel at least 20 steps.
- Divide the total distance (in feet) taken by the number of steps to get your stride length.
To adjust your stride length on your dashboard, please do the following:
- Log into your Fitbit.com dashboard.
- Click on the gear icon in the upper right corner of your dashboard and select "Settings."
- You will see a field for Stride Length and Running Stride Length. From here, you can manually enter your personal stride length. If you leave these blank, your profile will estimate these values based on your height and gender.
- Click the "Update Profile" button to save your changes. Note that a sync will be required to update your tracker with your new stride measurements.
I have a question on this as I tried to adjust my stride and cannt find the setting to do so from dashboard. everything makes sense except for there is no location for stride under the gear icon. Has the dashboard chnaged?
01-29-2015 15:58
01-29-2015 15:58
@SunsetRunner wrote:
Here is a link to instructions on how to change your stride length.
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-measure-and-adjust-my-stride-length/?q=change+step+length&l=en_US&fs=Search&pn=1.
Unable to find stride under settings has the dashboard changed?
Best Answer01-29-2015 16:25
01-29-2015 16:25
First go to the gear symbol in the upper right of your dashboard. Click on the gear symbol and choose "settings"
You'll see a bunch of categories on the left. Make sure you are on "Personal Info"
You should see your name and other information there. Scroll down a bit until you see stride length (it's under your gender and height and birthday info.)
Let us know if you find it.
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-measure-and-adjust-my-stride-length/?q=change+step+length&l=en_US&fs=Search&pn=1.Unable to find stride under settings has the dashboard changed?
05-03-2015 08:32
05-03-2015 08:32
My stride is correct but my zip is telling me that i only walked 1.98 miles at 13000 steps. i calculated a distance on google map to walk a flat 2 miles. what's wrong with my zip. sadly with short legs and to walk faster i have a foot and 2 inch stride
Best Answer06-12-2015 21:49
06-12-2015 21:49
I have found that about 10,000 steps can be as much as 4 to 5 miles.
@packgirl13 wrote:10,000 Steps equal how many miles? I am wondering
Best Answer06-13-2015 10:33
06-13-2015 10:33
Best Answer06-13-2015 11:58
06-13-2015 11:58
Best Answer10-25-2015 20:10
10-25-2015 20:10
Best Answer10-25-2015 20:12
10-25-2015 20:12
Best Answer10-27-2015 14:57
10-27-2015 14:57
Best Answer10-27-2015 18:15
10-27-2015 18:15
Best Answer10-28-2015 04:59
10-28-2015 04:59
I get 10K in 4 miles
Wendy | CA | Moto G6 Android
Best Answer01-22-2016 13:27
01-22-2016 13:27
I am trying to get my issue resolved. I went to my dashboard, clicked settings and do not see an option to adjust length/stride. I have the flex. Can anyone share if they have done this and how you did it? Many thanks!!
Best Answer01-22-2016 14:26
01-22-2016 14:26
Hilary | UK
Charge, Aria, iPhone 4s, Mac
If this answer is helpful, please vote for it and/or mark it as a solution.
09-25-2016 07:50
09-25-2016 07:50
Thank you. I thought that the distance depended on height and stride length. I have to take about 12,200 steps to get five miles, and I am about 5'3". That makes sense with your examples. My office mate insists that 10K steps is five miles. Now I know my instinct was correct, and it varies with height. Now I can trust the default stride length on my Charge and not go changing settings.
