05-08-2021 18:42
05-08-2021 18:42
I had an allergic reaction to it and was wondering what it is so I can avoid it
Thanks, Mikayla
05-08-2021 21:05
05-08-2021 21:05
Hi @Mikayla.s the band is made of an elastomer material. The only times I had a reaction to the band was when I got it wet underneath and didn't take it off to dry or I failed to clean the band when putting it on after charging. Keeping the band dry and clean, plus not putting it on a wet hand worked for me. I use rubbing alcohol to clean the band or a baby wipe, then use a clean washcloth to dry it.
