04-15-2020
10:24
17:08
04-15-2020
10:24
17:08
Hi, i have a flex 2 which i use at the moment for everything but id like to upgrade to a better model. I currently fasten my flex 2 under my uniform at work as i am unable to wear anything on my wrist or around my neck. Would a different model accurately monitor my steps if just looped around my bra strap?! and if not can i continue to use my flex 2 at work then use a better model for everything else?
thank you!
04-15-2020 12:28
04-15-2020 12:28
You should be able to use Flex 2 and alternate with another model. That is not possible with 2 of the newer models, but you should be okay with Flex 2.
See Can I use more than one Fitbit device with the same account?
