Hi @i-have-a-flex2 That is bad luck. Are you positive it is syncing? If so it must be within bluetooth range of your phone. If bluetooth finder doesn't help and you can't hear the alarm you set then you will just have to search very carefully and hope you come across it. Good luck
Helen | Western Australia
