10-02-2021 13:49
10-02-2021 13:49
while charging my battery on a train. i left it there. how do i go about getting another one?
10-02-2021 13:54
10-02-2021 13:54
Hi @georgie303 the battery is inside your Fitbit and there is no replacing it. You lost the charger unit? Either way, the Flex 2 is older and no longer being made. You'd need to go to a retailer such as Best Buy or Amazon to find a charger unit.
10-02-2021 14:05
10-02-2021 14:05
10-02-2021 14:06
10-02-2021 14:06
@georgie303 sometimes there is a lost and found for public transportation, so maybe check with them.
10-05-2021 12:38
10-05-2021 12:38
I just bought a replacement charger for my flex one on Amazon. It was only seven bucks 🙂
10-05-2021 12:55
10-05-2021 12:55
Hi @Sbaker41 be sure the charger has the pin hole so you can do a restart of the device. It's necessary.
