04-28-2020 06:43
04-28-2020 06:43
Several times a week I bike from 10-20 miles; I edit my daily stats to include those miles. The issue is the mileage is not included in my weekly stats which makes it look like I was not very active on “biking” days🙁
Any solutions?
Best Answer04-28-2020 08:14
04-28-2020 08:14
@TDray I'm fairly certain that steps or miles that are logged manually do not count in your weekly totals or in challenges. You're not actually walking or taking those steps, you're biking them.
Maybe put your Fitbit on your ankle to see if you can get it to count if it's important to you. But then your heart rate data may not be accurate.
04-28-2020 08:14
04-28-2020 08:14
04-28-2020 11:17
04-28-2020 11:17
Best Answer05-01-2020 07:03
05-01-2020 07:03
I can tell you from experience that the fitbit will only count "steps" taken while wearing a working fitbit. If it stops working and doesn't record your data, manually entering your miles/steps doesn't count toward your goals. I have lost many a mile because of this. Try the wearing on the ankle strategy. I do that when I mow the lawn, otherwise it doesn't count my steps as my arms are stationary. Good luck!
