01-23-2014 05:51
01-23-2014 05:51
Having difficulties logging in food that doesn't appear in the drop down. This program seems to calculate calories for foods that are in the drop down.
Best Answer01-23-2014 10:02
01-23-2014 10:02
If you can't find something using the drop down you can create your own foods. Look at the column to the right of where you log your food. Part way down you will see an option to "Create a new food". You can either look at the nutrition label on your food item or look it up on the internet. Add it to the food you have created and then you can search for it next time you eat it.
03-25-2015 16:46
03-25-2015 16:46
I don't want to have to create my own when the common food item should be in the Fitbit database.
Best Answer03-26-2015 03:56
03-26-2015 03:56
@JudyJ wrote:If you can't find something using the drop down you can create your own foods. Look at the column to the right of where you log your food. Part way down you will see an option to "Create a new food". You can either look at the nutrition label on your food item or look it up on the internet. Add it to the food you have created and then you can search for it next time you eat it.
That's right, that's the way to do it. It may be a bit tedious at first; but over time, within a couple of months, I found the need to add custom items came down to one or two items a month; and now, I can't even remember the last time I had to create one. If the food database included every single item available on the market place, which would keep changing every second, it would quickly become unmanageable and the response time would come down to a crawl.
TW
03-26-2015 09:56
03-26-2015 09:56
I found the FitBit food logging isn't my favorite. I simply use MyFitnessPal and link it to my fitbit account. Plus with MyFitnessPal I get free food reports and don't need to pay for fitbit premium or whatever.
